preggophilia.com
madnauseam
preggophilia.com
Post by madnauseam » 26 May 2023, 11:04
Is there any chance of having a template for the site/forum:
Thanks,
Re: preggophilia.com
Post by Maksym » 26 May 2023, 12:45
Looks like an account is required to view full-size pics. You can send account info to support@exisoftware.com. Also I need to know if images are only displayed with URLs like this:
preggophilia.com/attachment.php?aid=XXXXXX
Or is there any other type of images on this forum.
madnauseam
Post by madnauseam » 26 May 2023, 13:43
login Info sent.
yes, i believe so
Post by Maksym » 26 May 2023, 15:38
If you want all pictures from entire site, then why would you need a separate template? Have you tried the built-in template called "Download all images from entire website"? It should do the job. I can create a template for a thread - that makes more sense to me.
Post by Maksym » 26 May 2023, 16:55
Here is a thread template:
preggophilia.com thread downloader
madnauseam
Post by madnauseam » 26 May 2023, 20:39
Thank you very much!
Indeed you are right (bar some minor extra images which are not a problem). I was having trouble replicating the "Thread" structure in folders, all the items were being downloaded into the same folder.
I guess the only way is going thread by thread, using the template you provided!
Post by Maksym » 27 May 2023, 12:03
You are welcome!
