forums.socialmediagirls.com
dreamer29
Post by dreamer29 » 21 May 2023, 04:27
can you check on https://forums.socialmediagirls.com/thr ... 546/page-6 why the template dont download the imgur embed gifs or clips
Re: forums.socialmediagirls.com
Post by Maxim » 21 May 2023, 14:04
I updated the template. Now it processes stand-alone imgur posts that are embedded into the page. If you know a thread where entire imgur albums are embedded - give me an address for the tests.
dreamer29
Post by dreamer29 » 21 May 2023, 14:12
here on page 6 are imgur embed videos/gifs
Post by Maxim » 21 May 2023, 14:16
Yes, but they are separate embeds and they are already working in the updated template. Do you know a thread address where entire album is embedded?
dreamer29
Post by dreamer29 » 21 May 2023, 14:30
no i dont know but how can i do this with imgur embed clips/gifs on celebforum.to
Post by Maxim » 21 May 2023, 14:37
Download the updated template, create new project with your thread address, enjoy.
dreamer29
Post by dreamer29 » 21 May 2023, 14:41
which updated template i dont understand
dreamer29
Post by dreamer29 » 21 May 2023, 14:46
on this thread in celebforum.to is the same with imgur embed
https://celebforum.to/threads/leni-klum.111/page-8
Post by Maxim » 21 May 2023, 14:46
This template:
forums.socialmediagirls.com thread downloader
You can find many other templates by opening the Extreme Picture Finder templates library and pasting your URL into the search box or browsing the library page by page.
Post by Maxim » 21 May 2023, 14:49
The source of this page does not contain text "imgur", which means nothing is embedded into this page from imgur.com
