Hi. First of all, sorry if this is already solved but I couldn't find any post about it.
Is there any way to name the subfolders for every post as the page title (post title) instead of URL /post/XXXXXXX?
If so, how could I configure it?
Thanks!
coomer.party subfolders name
Re: coomer.party subfolders name
Well, it's pretty easy to use a page title to create a sub-folder name in Extreme Picture Finder. You simply open project properties, select the [ Sub-folder ] section, [ Advanced ] tab, check the [ Create a sub-folder name from a title of a parent page... ] box and enter a Regular Expression that matches URL of a page. In your case that's pretty easy:
/post/\d+
But there is a problem with this option when page titles use emojis (and coomer.party posts use a lot of them for some weird reason). In this case the folder name is not generated at all and file is saved directly into the [ Destination folder ]. I'll try to fix it, but right now - that is how it works.
/post/\d+
Thank you so much for your quick response, Maxim!
An option like "PostID + Page title" for subfolder names would be great (just a suggestion).
Thanks again!
Thanks again!
Agree, this would be very useful, and the date too if possible, it's just under the title.
Currently Extreme Picture Finder cannot use page text (except for the page title) to create file or folder names. Also, it cannot use a combination of options - only one selected option.
Hi. Would it be possible that instead of creating a subfolder, it could be added as a prefix to the image name?
Right now you can only have a fixed prefix and suffix added to every file name:
It cannot contain any generated text.
