Great software! Really loving it. I download alot from Yandex, and would like each image search to go into a sequentially numbered subfolder under a parent. So something like this...
yandex/001 (first search)
yandex/002 (second search)
I am currently manually creating this structure, but wonder with all the options available maybe there is a way to automate this that I am missing.
Thanks!
Sequentially numbered subfolders
Re: Sequentially numbered subfolders
Since you are downloading from Yandex - you are using your own projects, not the built-in picture search, right?
In this case you can use [ Create a sub-folder for each starting address ] option which was completely re-worked in version 3.64. You will need to check both [ Add starting address number ] and [ Add starting address domain name ] boxes to get sub-folder names like this:
001\yandex.com
002\yandex.com
You can also check the [ Replaces slashes with this text ] box on the [ Additional ] tab to make Extreme Picture Finder create sub-folders like this:
001-yandex.com
002-yandex.com
001\yandex.com
002\yandex.com
001-yandex.com
002-yandex.com
