Hello, I would like to know if the number of simultaneous connections impacts on the success of downloading files.
I noticed that when I increase the number to something above 5, some files are not downloaded.
Is there any way to speed up the process without leaving files behind?
Thank you!
Number of Simultaneous Connections
Re: Number of Simultaneous Connections
Some servers will not even allow more than 1 connection. They will simply ban your IP or just prevent other files from downloading while you are already downloading one file. So, it doesn't entirely depend on the program, unfortunately. And you'll have to experiment to find the best number of connections yourself. And that number will be different for every server you are downloading from.
