amabitch project template not working
jonkeydonkey
Post by jonkeydonkey » 06 Oct 2022, 11:19
There are some links on amabitch that links to imagebam, they are not downloaded.
This one for example: http://amabitch.com/index.php?postid=7520
On imagabam, there is a "wait" before the real link appears, not sure if that's the problem or not.
I added the imagebam urls to the included urls in the filtered list, but it seems like the software just follows the link to the page that says something like "wait you're url is finished soon" and then it's completed. However it should wait until the "continue to your image" link appears and then follow it.
Can this be solved by configuration?
Re: amabitch project template not working
Post by Maxim » 06 Oct 2022, 15:33
I updated the project and added necessary filters to the [ Included URLs ]. Re-download the project:
www.amabitch.com - free amateur porn pictures
In order to download such galleries from imagebam.com you have to use only 1 simultaneous connection and Extreme Picture Finder version 3.60.2 or higher.
jonkeydonkey
Post by jonkeydonkey » 07 Oct 2022, 14:23
Tried the new project, I see that you have changed the regex for included urls. Did you change anything else? However it's still not working.
I'm using the latest released version of the software.
For example:
From the download log I get a http 200 response from url: https://www.imagebam.com/image/d0a8a7333106751
but nothing is downloaded. If I try to to open the url in my browser I get to a page which says something like "wait for your url". After about 5 seconds, the link changes to continue to your image, and it points to "https://www.imagebam.com/image/d0a8a7333106751"
Nothing is dowloaded.
Any idea?
I'm using only one connection, and also increased the wait between downloads to 5-10 seconds.
Post by Maxim » 09 Oct 2022, 12:52
OK, this time I fixed it for real. I used [ Custom HTTP referer ] to remove the HTTP Referer field for all imagebam.com URLs - check it out in the project properties, [ Site exploration -> HTTP Referer ] section. And now you can use any number of connections without a delay between downloads to get images from imagebam.com galleries.
jonkeydonkey
Post by jonkeydonkey » 09 Oct 2022, 22:06
thanks for your support! it's downloading again, I did experience some issues with some galleries but I'll need to look into that further, I'll keep you posted
