simpcity.su
diver4321
simpcity.su
Post by diver4321 » 27 Aug 2022, 16:51
Hello, looking to see if anyone has a template that works with simpcity.su?
similar templates are found here -- viewtopic.php?f=4&t=10759
appreciate any help :)
Re: simpcity.su
Post by Maksym » 28 Aug 2022, 13:00
Looks like an account is required to view the content of this forum. Can you send me a working account info to support@exisoftware.com?
diver4321
Re: simpcity.su
Post by diver4321 » 28 Aug 2022, 13:15
Hey Maxim, all sent :)
Re: simpcity.su
Post by Maksym » 29 Aug 2022, 13:59
OK, please try this template and let me know if it worked for you:
simpcity.su downloader
diver4321
Re: simpcity.su
Post by diver4321 » 29 Aug 2022, 15:41
Hey mate,
appreciate this! thank you :)
few changes I had to make otherwise it was just grabbing 1 image and that was it but now it works perfectly.
Modify project properties:
Save -> Sub-Folders under expert, change thotbay to simp city on line 3:
Code: Select all
 simpcity\.[^/]+/albums/([^/\?#]+)
under filters--> included urls: change thotbay to simpcity:
Code: Select all
^https?://(www\.)?simpcity\.[^/]+/albums/[^\?/#{}"']+$
Code: Select all
^https?://(www\.)?simpcity\.[^/]+/api/v2/data\.php\?action=album-files
Re: simpcity.su
Post by Maksym » 29 Aug 2022, 16:04
OK, thank you very much! I fixed that. Please re-download the template.
diver4321
Re: simpcity.su
Post by diver4321 » 29 Aug 2022, 17:20
all seems to be working perfectly :) thank you!
diver4321
Re: simpcity.su
Post by diver4321 » 31 Aug 2022, 00:57
Hiya mate,
just a update they have changed the url to .su
so https://www.webimagedownloader.com/temp ... ownloader/ needs to be updated to reflect .su (no need to change anything else it works as expected :)
Re: simpcity.su
Post by Maksym » 31 Aug 2022, 12:35
Hey, thanks for that! Template updated.
steal107
Re: simpcity.su
Post by steal107 » 14 Sep 2022, 19:14
Maxim, this works fantastic just like the Thotsbay you originally made for me with downloading entire threads, have a quick question, how do I download just a new post off of a thread. I tried multiple things and it just starts downloading the entire thread again instead of just the update post I want. Any suggestions?
