BravoErotica Template
merc_slk
Post by merc_slk » 19 Apr 2022, 14:52
Is it possible to adapt the way subfolders are created? I'd like to split up more. Now it's only by file name. ex. :
https://www.bravoerotica.com/met-art/anita-c/astonish/....
https://www.bravoerotica.com/met-art/lidia-b/hands/
https://www.bravoerotica.com/x-art/eufrat/seductress/
Adults/
L--> Babes/
L-->Bravoerotica/ My Downloadfolder
L-->met-art/ Website
L-->anita-c/ Model
L-->astonish/ Folder Shoots
L-->lidia-b/ Model
L-->hands/ Folder Shoots
L-->x-art/ Website
L-->eufrat/ Model
L-->seductress/ Folder Shoots
Just to gather collections from the same website in one folder. If any other templates have a similar pattern, might be a nice idea to adapt?
Regards,
Jef
Re: BravoErotica Template
Post by Maxim » 20 Apr 2022, 13:11
Are you talking about the existing template? Or you want a new one? I couldn't find the one for www.bravoerotica.com.
merc_slk
Post by merc_slk » 20 Apr 2022, 14:31
I´ll check later, downloaded the template from your site. On the road now.
Post by Maxim » 20 Apr 2022, 14:34
Maybe you meant a project, from the projects library? Because there is a project for that website. But no template.
merc_slk
Post by merc_slk » 22 Apr 2022, 12:48
Sorry, you're right it's a project. My mistake. How can I adapt to group sites as subfolders? thank you.
Post by Maxim » 25 Apr 2022, 13:07
OK, I re-created a project from scratch to make it work better and create more logical sub-folders. Please try it ad let me know if this is what you wanted:
BravoErotica.com - Beautiful Nude Girls
merc_slk
Post by merc_slk » 16 Jun 2022, 12:36
Maxim,
Sorry for the late reply.
Thank you for your time and effort but still it's not the sub folder creation I was thinking off.
ex.
https://www.bravoerotica.com/all-gravur ... low-sweet/
https://www.bravoerotica.com/playboy-pl ... -lingerie/
https://www.bravoerotica.com/met-art/nancy-a/druentica/
https://www.bravoerotica.com/playboy-pl ... h-caramel/
Your script creates these sub folders : yellow-sweet/, luscious-in-lingerie/,druentica/....
For me a logical approach if possible and also for other projects would be :
Top level/Root folder the Website : all-gravure, playboy-plus, met-art
Sub-folder Model name : saya-hikita, noelle-monique, nancy-a
Sub Sub Folder Kind of Shoot Name : yellow-sweet, luscious-in-lingerie, druentica
In this case the directory build would be like this :
>all-gravure/ (root)
--------------->saya-hikita/ (sub-folder)
------------------------------>yellow-sweet/ (sub sub folder and pictures)
>playboy-plus/ (root)
---------------->noelle-monique/ (sub-folder)
------------------------------------>luscious-in-lingerie/ (sub sub folder and pictures)
---------------->cierra-avalon/ (sub-folder)
--------------------------------->smooth-caramel/ (sub sub folder and pictures)
>met-art/ (root)
----------->nancy-a/ (sub-folder)
---------------------->druentica/ (sub sub folder and pictures)
----------->bettina-b/ (sub-folder)
----------------------->presenting-bettina/ (sub sub folder and pictures)
I don't have enough skills using regex and I'm not sure if this is even possible.
Thank you,
Jef
Post by Maxim » 16 Jun 2022, 13:36
But that is exactly the result the new project is delivering. Take a look:
I think you need to delete the project from Extreme Picture Finder along with downloaded files first, then re-download the project file from the project page and re-start it from scratch:
bravoerotica.com - beautiful nude girls
merc_slk
Post by merc_slk » 27 Jun 2022, 13:07
Thanks, This did it. I need a deep dive in those settings to understand and make my own project list. Great work.
