nudecollect template
Hello everyone,
I am trying to download pictures from a handful links on www.nudecollect.com.
It always worked fine with the template "www.nudecollect.com - category template (ver.10)", but since a few days, i only get 3-5 pics downloaded of a gallery that contains about 100.
As there is no new template available on the website, is there anything I could do to correct the problem ?
Here is one of those links : https://www.nudecollect.com/content/Thi ... 2-102.html
Software Version : 3.60.2.0
Thanks in advance for your help
Re: nudecollect template
Here is the generic template which can download photos from any part of the website:
nudecollect.com downloader
They implemented additional layer of protection, so a delay between downloads is now required (along with some other magic). And no simultaneous connections - only one. Otherwise nudecollect.com bans your IP.
Hi Maxim,
Thanks for your quick reply. Thank you for your work, help and sometimes patience :)
go on with it!
Cheers
go on with it!
Cheers
I actually found a way to download the whole gallery.
I open the image in the highest resolution on a new tab, copy the image address and use the url generator.
Its a bit longer as I have to do it for each gallery, but it works.
Hmm. Direct image URLs... Interesting. Maybe I'll find a way to automate it.
I did it! Here is the template:
The template is generic - it works with any part of the website.
True enough,
No worries and thanks anyway.
However what would be great as a functionality is to be able to change the template in the project properties itself.
That could allow you to have one project but with multiple sources.
You can do it. You can change the template properties and properties of any selected project.
If you want to modify project properties - simply select the project and use menu item [ Project -> Project properties... ].
If you want to modify the properties of the project inside the template - select the template in the template browser (menu item [ Templates -> Open local templates library... ]).
Use menu item [ Template -> Template properties... ]. And the click a big button at the bottom of the template properties window - [ View/modify project properties... ].
