Imagebam template v5 stopped working.
Hopefully one of the experts can assist.
Imgagebam v5 template not working
Re: Imgagebam v5 template not working
I updated the template, but it requires more steps to download full-size images now:
www.imagebam.com - gallery template
Once you start the project created with this template - you will have to click any thumbnail in the built-in browser and actually see the full-size image in it (may require another click) and only the click [Continue download] button and enjoy full-size images.
Please try it and let me know if it worked for you.
Maxim thank you for your quick support.
The issue may be my version of the software, I am using v3.59.
The browser screen with thumbnails appeared but I was not able to click to get the full size image.
This is the site I was attempting to download:
http://kitty-kats.net/threads/my-nylon- ... 534/page-7
I will attempt to upgrade software
You should have said so from the very beginning. The imagebam template is for imagebam galleries only. I'll have to update the program (I'm working on it right now) to make it work with other sites linking directly to imagebam image pages.
OK, it's done. You should download and install the most recent version of the program:
And use this template:
kitty-kats.net - thread template
Please try it and let me know if it worked.
Maxim, you are correct I should have provided more information in my original post. Thank you for you patience and willingness to assist.
Your template WORKS!!
Truly not complaining and sharing my experience
If I ask for -
https://kitty-kats.net/threads/my-nylon ... 534/page-8
I will get -
https://kitty-kats.net/threads/my-nylon ... 534/page-3
Any thoughts?
If I ask for -
I will get -
Any thoughts?
The template downloads all images from all pages of a selected thread. If you want images from only 1 page - remove first filter in the [ Included URLs ].
Very NICE!!!
Also I have gained a bigger appreciation for the support you have provided. The work you put into Included URL's is impressive.
Great job and thank you
