Hi.
I had downloaded a gallery using the pornpics template previously and it had completed. Now when I try to restart or update the gallery, it errors out. The download log says "Filtered by Excluded URLs."
The same happens if I try to setup a new project with the same set of URl(s).
If I remove the ".*" entry under the Excluded URLs section and start the project it works but downloads pictures from other sources/URLs. Once the project starts, if I go in and put the ".*" back in, it works as normal.
Can anyone help?
IQ
Getting "Filtered by Excluded URLs" when trying to update/restart download
Re: Getting "Filtered by Excluded URLs" when trying to update/restart download
What is the gallery URL?
