ignore list
ignore list
The program needs at ignore list, by right click on picture > to ignore-list, a lot of spam is beeing downlouded
Re: ignore list
Every project and search has it's own ignore list in the program. It is called "Excluded URLs" and is located in the project (or search) properties [ Filters -> Excluded URLs ] section.
If you want a permanent ignore list for all your project - create a template with that list and use it for your projects.
If you want a permanent ignore list for all your searches - add all addresses to that list and the click [ Make these properties default for all searches... ]
