It would be nice to be able to have a check box, maybe next to the "Manual Login (for website that with HTML forms)" Check box, that says like "Auto Continue Download" that would have the "Continue Download" button automatically click itself when the page loads in the browser. This would be good for projects where your login token is stored in the browser's cookies.
I have a ton of projects for individual users on a certain site, well over 800, and it is a pain to have to click the button for each of them as they come up when I do an update pull. Or to have to dedicate my PC to the sole task of using an auto clicker. It would be nice to be able to start an update on the category and set it up so I only have to click the "Continue Download" Button on the first project and then set the rest to automatically do it when they start. This should be a project setting. Then I could go on to do other things as the application just sits there and does its thing.
New Feature request - Auto "Continue Download" option.
Re: New Feature request - Auto "Continue Download" option.
OK, adding it to the to-do list. Thank you for the suggestion.
No problem. As a fellow developer, I am happy to throw my 2 cents in.
This feature was added to the most recent version. Please try it and let me know if it worked as expected for you:
Yes, I have tried it. So far it is what I was thinking of. I will continue to test it out and let you know if I find anything.
BTW this is AWESOME!
Thank you very much!
