Base64 Decode
Base64 Decode
It's possible to decode a base64 url in the custom parser?
Re: Base64 Decode
Not yet, but it's in the to-do list and can be added. Can you give me a sample URL where this feature can be tested?
Re: Base64 Decode
Here in this page this specific href is encoded in base64:
https://www.anbient.com/Tv/Bleach%20
Code: Select all
<a class="ajax padrao" href="L2FuYmllbnRfdXRpbHMvYWpheC9kb3dubG9hZC8yNTkx">
Re: Base64 Decode
It is done. You are welcome to download the new version:
Please try it and let me know if it worked for you.
Re: Base64 Decode
Amazing, worked great, thank you for the fast response/solution.
Re: Base64 Decode
You are welcome! Glad I could help!
