Example: https://rule34.xxx/index.php?page=post& ... ags=female
There's already a template for this website but it doesn't always work like it's supposed to as it downloads unrelating files.
Updated template for www.Rule34.xxx
Re: Updated template for www.Rule34.xxx
Template updated:
rule34.xxx - tag template
But I found out that it was downloading less than it was supposed to. Nothing unrelated. Please try download the most recent version of the program too:
I was wondering, is it possible to use Extreme Picture Finder via a proxy/VPN (if this is a sensitive topic, please remove that comment!)? rule34.xxx is blocked where I live, and I can only access it this way.
Yes, you can use Extreme Picture Finder with a proxy. Open program settings, select [ Internet -> Proxy ] section and enter your server parameters.
Great, thanks for your answer! A lot of sites are blocked, and that's a pain to get around it without a proxy...
