Template Request - WhatBoysWant
ThisIsAnExperience
Post by ThisIsAnExperience » 10 Feb 2021, 02:45
I am still a bit green when it comes to building templates. If anyone could help with building a template for the various categories on WhatBoysWant.com, it would be greatly appreciated.
Seems like the picture are housed in the subdomain of "Babes" and then broken into categories. For example:
https://whatboyswant.com/babes/topless-babes
https://whatboyswant.com/babes/naked-babes
I will keep tinkering with it to see if I can get it to work, but any help would be appreciated!
Re: Template Request - WhatBoysWant
Post by Maxim » 10 Feb 2021, 15:12
Here is a template for any photo category on this website:
whatboyswant.com - photo category template
Basically all you had to do was selecting [ Current directory and deeper ] in the [ Site exploration -> Regular site ] section. Please note that it'll work correctly only in version 3.53.2 or newer because in this version that [ Current directory and deeper ] exploration method was reworked.
ThisIsAnExperience
Post by ThisIsAnExperience » 10 Feb 2021, 20:02
This works, thanks! I tried roughly the same thing but was having issues with the tool grabbing avatar images and thumbnails.
Post by Maxim » 10 Feb 2021, 20:15
Well, a couple of filters in the [ Excluded URLs ] removes the unwanted content easily.
ThisIsAnExperience
Post by ThisIsAnExperience » 10 Feb 2021, 21:03
I figured that would be the case - just still new to the notation and how to get things working how I want.
Any way to get the pictures to save with the file name being the parent webpage url where the picture is displayed? Thanks again, for the help.
Post by Maxim » 11 Feb 2021, 12:20
Sure! Take a look:
If you want a direct parent - then just use
a single dot in the [ Regular Expression ] field. A dot matches any symbol, so the first parent URL will match it.
ThisIsAnExperience
Post by ThisIsAnExperience » 12 Feb 2021, 18:02
You're the best, thanks!
