Dare beauties
Dare beauties
been trying to download images from this site
https://darebeauties.com/
but get not a single mage ends with error "http: code -1 , socket code 0
Googling the code suggests it may be blocking the software?
Increased the download interval to 15 to 20 seconds but no better.
Please advise. Thanks.
Re: Dare beauties
I created a generic template for this website which allows to download all photos from any tag model or any other part of the website:
darebeauties.com - tag and model template
Obviously I did not get the "-1" error. So my suggestions would be:
1. Make sure you have the most recent version of the program:
2. Use [ Manual login ] to open the website in the built-in browser to see if you need to solve a CAPTCHA to unblock your IP or any other message from the website.
Re: Dare beauties
ok Thanks.
Time I upgraded as my version can't use this template format.
Re: Dare beauties
Ok I have upgraded and added the template.
But the settings and urls if I try to select and only download certain model page images are still downloading all.
eg : Lets say I want
https://darebeauties.com/josefin-pettersson/3164/
https://darebeauties.com/michelle-lewin/3176/
etc etc
Please advise
etc etc
Please advise
Re: Dare beauties
This template was created to download all pictures of any selected model or tag. The URLs you are trying to use contain only 1 picture of a model. You can use a built-in generic template called "Download all images from a single-page gallery" to download from such pages.
Re: Dare beauties
Ok, yes the link was incorrect for multiple images of the same model
should be :
so how do I select specific models for multiple download as you say.?
should be :
Re: Dare beauties
Here are the detailed instructions showing how to use templates:
How to use templates
Basically, you need to download and install the template, then create a project with URL(s) the template was created and for and make sure the template is selected by clicking [ Next > ] button after pasting your URLs.
Re: Dare beauties
Ok, the problem was that I had to completely "restart" the scan when adding specific urls to the starting addresses
rather than "Start" or "resume".
Working now selectively.
