Projects and updated Templates
Thwack
Post by Thwack » 27 Jan 2021, 21:44
When a new version of template is downloaded, do the existing projects that are based on the old template get updated as well? Or is there some steps that I need to follow to update the projects with the new template version?
Thank you
Re: Projects and updated Templates
Post by Maksym » 28 Jan 2021, 13:06
Currently nothing is done automatically to existing projects. Sorry. The only way to apply new settings from new version of the template is to create a new project. I guess I'll add it to the to-do list.
Thwack
Post by Thwack » 29 Jan 2021, 18:40
Thanks, Maxim!
