Maybe some hits how to download from this site?
kaosnews
Post by kaosnews » 22 Jan 2021, 14:24
For some reason I can't download correctly from this site: https://kenzato.uk/booru/category/HS2/? ... seek=C7UxV
I tried different methods but I can't get only the correct files. The correct images are mostly the thumbs (it's correct that the images are small), but some images are in this format: *.md.png and I don't want to download these.
I tried Custom Parsers because the correct downloaded image is in this tag:
<div class="list-item-download" style="float: right;"> <a href="https://kenzato.uk/booru/images/2021/01 ... 245047.png" download="HS2ChaF_20210122031245047.png" class="btn-icon icon-download5" target="_blank"></a></div>
and with the custom parsers I could filter these links.
Is it possible to only use the links from the custom parsers? I could use excluded parts but you will only get the first image. Maybe some tips how to solve this?
Re: Maybe some hits how to download from this site?
Post by Maxim » 22 Jan 2021, 15:17
Try adding
to the "Excluded URLs" filter.
kaosnews
Post by kaosnews » 22 Jan 2021, 16:22
It's still downloading these images.
Excluded URL:
Code: Select all
Included URLs:
Code: Select all
https://kenzato.uk/booru/images/\d+/\d+/\d+/[^#]+$
https://kenzato.uk/booru/category/HS2Scene/\?page=\d+&seek=\w+
Post by Maxim » 22 Jan 2021, 16:54
Oh, if you have these "Included URLs" then those filters that I suggested are useless. "Included URLs" have the priority. Maybe try adding the following excluded page part:
To: >
This will exclude all image tags, but since the links that you need are inside the <a href=...> tag - you should be fine.
kaosnews
Post by kaosnews » 22 Jan 2021, 17:24
Ah I understand now why Included overrules excluded.
It's fixed now. It's downloading the correct images. Thanks!
