template for hentai-cosplays.com now blocked in crawler?
p0rnseeker
Post by p0rnseeker » 11 Nov 2020, 18:57
Your project finished but zero target files were saved
Re: template for hentai-cosplays.com now blocked in crawler?
Post by Maxim » 11 Nov 2020, 19:18
Have you tried using [ Manual login ] to unblock?
p0rnseeker
Post by p0rnseeker » 12 Nov 2020, 00:40
there is no login button...
protected by reCAPTCHA
Post by Maxim » 12 Nov 2020, 12:04
You can check [ Manual login ] box in the project properties, [Starting Addresses] section in Extreme Picture Finder. In this case you will see a built-in browser right after you start the project. And you'll be able to solve captcha in this browser and continue the download.
