Feature request: _global_ URL exclusion
ataraxia
Post by ataraxia » 14 Jul 2020, 15:53
Would be great to have one place to enter all URL's to be excluded from searches.
That way, each time my anti-malware program identifies an "undesireable" site, I can add the URL to a centralized master exclusion list. Then it will be applied to all of my future searches for all sites.
Thanks.
(BTW, Great program!!)
Re: Feature request: _global_ URL exclusion
Post by Maksym » 14 Jul 2020, 17:00
There is such place in the program and it's called "default search project". After you create a search with all your excluded URLs open the search properties and click the big button at the very bottom of the properties window which says [ Make these properties default for all searches... ].
This will save all the settings you choose (along with Excluded URL filters) and use them for every new search you create.
ataraxia
Post by ataraxia » 14 Jul 2020, 18:24
Not quite...
The default screen applies only to NEW searches.
Changes to the default do not change EXISTING searches.
I.e. If I add XYZ.com to the exclusion list in, say, the 77th search item in my list and set it as the default, it does not show up in my #8 search or any of the other ones already there.
(Unless I am missing something???)
thanks
Post by Maksym » 14 Jul 2020, 18:52
Yes, you're right. Only for new searches.
