Encoding issue
nnina084
Encoding issue
Post by nnina084 » 10 Feb 2020, 03:37
The title of the page in EPF and the page is saved with wrong coding.
Example: ćčçíč
Applies to pages with Cyrillic (coding CP-1251)
Windows 7 OS Polish
Re: Please fix the serious bug! Cyrillic (coding CP-1251) Russian all website
Post by Maxim » 10 Feb 2020, 18:05
I need the page address for the tests.
nnina084
Post by nnina084 » 10 Feb 2020, 19:15
https://stihi.ru/
Please test:
Save: Naming: (4 sub-option) Basic
Post by Maxim » 10 Feb 2020, 19:36
What is the 4-th sub-option? Current date + numerical?
nnina084
Post by nnina084 » 10 Feb 2020, 19:51
I installed EPF and used all the default settings.
After downloading the file, the HTML file in the browser shows the damaged charset. Invalid encoding.
Post by Maxim » 11 Feb 2020, 18:09
This website does not provide character encoding in the page text, so page context is shown in the default encoding of your Windows (which is Polish as you said before). On Russian version of Windows the saved files are displayed properly.
nnina084
Post by nnina084 » 14 Feb 2020, 13:16
There is a problem with the correct display in Firefox.
Everything is ok in Google Chrome and Chromium
Code: Select all
Firefox -> More -> Coding Text -> Unicode
Info: ISO-8859-2
Cannot set a different encoding. Options blocked.
The correct encoding is 1251
Post by Maxim » 14 Feb 2020, 14:51
Extreme Picture Finder saves files as they are. It does not change encoding in the process.
