Yopriceville and ClipartPNG template help needed
hansart
Post by hansart » 25 Dec 2019, 12:43
Hi guys,
Can someone help me with a template for:
https://gallery.yopriceville.com
https://clipartpng.com
These (free) sites are somehow related, but I guess I have to use 2 templates? One for each site?
If I search this board for an existing topic about these sites, I find nothing.
I'm a newby to Extreme Picture Finder, but I have purchased a liscense key, so i hope you can help me with this question.
Mary Christmas & a Happy Newyear.
Regards,
HansArt (dutch)
Re: Yopriceville and ClipartPNG template help needed
Post by Maksym » 26 Dec 2019, 15:34
Have you tried the built-in generic template called "Download all images from entire website"? I just did and EPF did the job pretty well. You can also limit the size of the saved files to get rid of the thumbnails... You see, you do not need a template for every website with Extreme Picture Finder. It can work on default generic settings.
Or you want to download only some part of the website's images, not all of them? If yes, then tell me exactly what do you want to download and I'll try to help.
hansart
Post by hansart » 26 Dec 2019, 19:05
Maxim,
Thank you very much!
I'll try the template you suggested. After that, perhaps I should break it up in smaller parts, by gallery or so. I'll let you know if I need any further help for that part.
Kind regards,
HansARt
hansart
Post by hansart » 26 Jan 2020, 18:18
Maxim,
Your suggestions helped a lot. All downloads went well.
Thank you.
Regards,
HansARt
