Pictures missing
Faehya
Pictures missing
Post by Faehya »
i am new with EPF, i use this template :
https://www.webimagedownloader.com/temp ... ed-author/
to download all user picture but some pictures is missing, for example : the user have 200 pictures, EPF display only 50 (the browser when i manuel login) and i download only 25 of them, even with 1 simultaneous connection and all files extensions in project properties...
What i don't understand is that the pictures not downloaded has nothing more or less than the others.
I am doing something wrong? the template need a update?
Re: Pictures missing
I can check it out if you give me exact URL you're trying to download from.
Faehya
Post by Faehya »
it's not the only URL but for example : http://www.hentai-foundry.com/pictures/user/Suumunster 69 of 117 pictures download
Check this out:
This is where the actual number of downloadable pictures is shown. And that's exactly the number Extreme Picture Finder saves.
Faehya
Post by Faehya »
yes for this one, but here : Image
only 19 downloads and why EPF does not download the 117 images, only 69 of them ?
(http://www.hentai-foundry.com/pictures/user/RukiFox)
Your screenshot shows that this profile has 34 pictures. And that's the number of pictures EPF saves from it. There are 2 pages with pictures there. One page contains 25 pictures, the other one has 9. I have no idea what "101" means and where to find 101 pictures in this profile. So please show me where can I find more than 34 pictures in this profile.
Faehya
Post by Faehya »
You can find 101 pictures on the website of HF Image is it what i don't understand EPF find only 34
But you see the screenshot I posted, right? Why does it show me only 34 pictures and you see all 101? Do you have to be logged in into the site to see all of them? Do you have an account on Hentai Foundry?
Faehya
Post by Faehya »
ho thank you, i just need to login with EPF on HF to see all pictures
thank you for your help
