Hi there! First time trying "Extreme Picture Finder" and the reason is to download many .htm files from a website where i manually logging in. It works great to my purpose but i have to enter in many different categories (almost 50) manually each time and clicking the "Download Now" button. Just wondering, is there any way to download all these different links at once?
My first idea was to enter in my project all these links of the categories in the field "Starting addresses" but it only downloads the first link and then stops.
Then i tried to create 50 different projects but again if i select all of them and click the "Start/Resume", i get an error and nothing happens.
Is there i way i miss to do that?
Thank you very much for your help.
Download multiple links at once
Re: Download multiple links at once
If all your Starting URLs are on the same domain then you need to add all of them to one project and you'll have to log in only once. Most likely this failed for you because of incorrect project settings. If you send me you URL list along with the login info to support@exisoftware.com then I can try to help.
Hi Maxim! Just sent you an email!
Thank you in advance for your help!
