Extreme Picture Finder v3.44 Problem
neroneronerop
Post by neroneronerop » 07 Sep 2019, 09:04
since update 3.44 i can´t configure some values like "template-folder" and so on. I configure the folder in the config-file and the first start it works, but after the second start the values are different and (for example) the "template-folder" is "standard". With version 3.43 i don´t have this problems. Can someone tell me how to fix this? :)
Re: Extreme Picture Finder v3.44 Problem
Post by Maxim » 08 Sep 2019, 12:48
Where is the "template-folder" option located? In the program settings?
neroneronerop
Post by neroneronerop » 14 Sep 2019, 01:03
Maxim wrote:
08 Sep 2019, 12:48
No it is located: D:\Extreme.Picture.Finder.Templates\
neroneronerop wrote:
07 Sep 2019, 09:04
This location works with version 3.43
Post by Maxim » 14 Sep 2019, 14:49
Please run Extreme Picture Finder as Administrator, open program settings, select the [ Advanced ] tab and change the location of Data folder using the Select... button located right under the current folder name.
Then make sure all files and folder were copied from the old location to the new one using Windows Explorer.
neroneronerop
Post by neroneronerop » 09 Nov 2019, 13:44
Maxim wrote:
14 Sep 2019, 14:49
thx for your help. but it don´t work.... when i restart (or end and start) Extreme Picture Finder I have the default path in the settings again.
I will try it the next time with the new version. and btw (i have backuped the old tool v 3.43) there are no problems with the paths. there i can change it in the setting (Tools -> Settings) or in the config file. both work in v 3.43 :/
Post by Maxim » 10 Nov 2019, 12:50
OK, I'll have to check it out. Thanks for the report.
