Only Log Hyperlinks
neroneronerop
Only Log Hyperlinks
Post by neroneronerop »
maybe I only haven´t found it but can the software make a "list" of our searchterms?
For Example:
Site:
http://kitty-kats.net/threads/nadine-j- ... 1.2308447/ till http://kitty-kats.net/threads/nadine-j- ... 47/page-19
Links I want to "list":
k2s.cc
or
ul.to
Output (after the tool has finished):
http://k2s.cc/file/0380730aaa1e1/Boobie_Woobie.rar
http://k2s.cc/file/08ad5b39026bd/Coffee_Break.rar
... (and so on)
Thanks in advanced
Re: Only Log Hyperlinks
Actually you can. First you have to create a project which will go through all thread pages and collect the links. Like this one:
kitty-kats.net - archives from thread
(use right-click, Save file as... menu item to save the project file)
Then you run the project and let it finish. It will save all the ".rar" files (which are actually pages) so bandwidth won't be taken.
Then you use menu item [ Project -> Export file list... ] and select Target file URL column, just like show on the screenshot:
That's it. Now select the file name and click OK and it's all done.
You can create a template from the above project to make it easier for you to grab archive URLs from other threads. Menu item [ Project -> Create template from project... ]. Plus you can automate the creation of the URL list in the project properties, After completion section.
neroneronerop
Big thx! Works great!
neroneronerop
sorry i have the next problem and can´t find a way to solve it.
The template works fine, with this kind of URLs:
But with this kind there are problems because the "*.rar" (or *.zip) is not in the URL. But the Links are RARs:
can someone please help me with this?
I don't think it's going to work. There are no direct links to ZIP files on ul.to. The RAR links are generated with JavaScript.
neroneronerop
"this have to go"! :)
i tried a few tricks like add ".rar" to the URL, so the tool can see the "file" .... and another few ideas.
btw. is it possible to get / export the log of the project? there have to be the links in it :) i will try again.
maybe on of you has the elementry hint :) or the working template :D
the in advance
Of course you can export entire log. Simply let the project finish, use menu item [Project - Export file list...] and select "All downloaded files and pages in the [What to export] section.
neroneronerop
big thx for your help... didn´t work so far, i try it again when i have more time
