I need help with this site
https://alpha.wallhaven.cc/search?q=gir ... esc&page=2
I try do it by my self without understanding what kind of expression i need, i use the exemple of "wallencraftpaper.com - category template (version 2)" but don't works for me, i download pictures that i don't asked (search) for.
I did like this :
In Starting URL Template :
alpha\wallhaven\cc/catalog/.+?
alpha\wallhaven.cc/search/\?query=
I know that i do something wrong.
Is possible you make an template of this site
Thank you
Searching alpha.wallhaven.cc
Re: Searching alpha.wallhaven.cc
Here is a template for you:
alpha.wallhaven.cc - search template
Regular expressions in the "Starting URLs" field on the template editor are used to automatically detect if template can work with the URLs you paste in the [ Create New Project ] window. The main working Regular Expressions are located inside the project properties. You can see them if you click the [ View/modify project properties... ] button at the bottom of the template editor window.
So it's better to create a working project first and then create a template with those project settings for other URLs from the same website. If you just want to download results of only one search phrase - you don't even need a template, you just need a working project. You only need a template if you want to download again and again from different parts of the same website, like from different search queries or from different categories.
But in any case you need to create a working project first.
Thank you maxim for your work and template.
I did what you said, make first project (what i did).
But on picstatio.com i try but i get only small images or images that i don't look it for.
I think I am not made to do this, not at all gifted.
I try with https://picstatio.com/wallpaper?utf8=%E ... earch=girl ,but no luck.
Can you make also this template, i know i ask alot of you, sorry
But thank you for you help.
Irving
Irving
