Program keeps hitting security alarm on fetlife
Superman627
Post by Superman627 » 06 Oct 2018, 17:47
Hello I got a problem whenever I try to get stuff from fetlife it keeps hitting the security alarm and then it locks my account because of it I mean everything works perfectly fine and the program works for a couple a galleries then the website fetlife locks me out due to security so is there any way to fix this. Thanks
Re: Program keeps hitting security alarm on fetlife
Post by Maxim » 08 Oct 2018, 12:02
Please try using a delay between downloads (2-4 seconds) in the project properties and use no more than 3 simultaneous connections. It may help prevent security alarm trigger.
