template for listal
ticotexas
template for listal
Post by ticotexas » 29 May 2018, 23:31
hi, can you make a template for a gallery such as this? http://www.listal.com/angelina-petrova/pictures/
Re: template for listal
Post by Maxim » 30 May 2018, 12:35
ticotexas
Post by ticotexas » 12 Jun 2018, 17:40
thank you. can you figure out this one? it seems to use javascript
https://www.davidmoserphotography.com/gallery
Post by Maxim » 14 Jun 2018, 12:19
Create a project using a generic template called "Download all images from a single-page gallery", then add the following Custom Parser:
Regular Expression: "uri":"([^"]+)"
Result: https://static.wixstatic.com/media/[#1]
And start the project.
