replace string
KAIAD
replace string
Post by KAIAD » 01 Apr 2018, 03:28
hi!
I want to change urls
from
http://dcimg8.dcinside.co.kr/viewimage. ... ebbdb884de
to
http://image.dcinside.com/viewimage.php ... ebbdb884de
i mean "dcimg8.dcinside.co.kr" to "image.dcinside.com"
any Regular Expression?
thanks for reading
Re: replace string
Post by Maksym » 01 Apr 2018, 15:49
Well, you can only apply Custom Parsers to the page text. And usually URLs are located between quotes. If that's so, then you can use the following Custom Parser:
Expression: "(https?://)[^/]+/([^"]+)"
Result: [#1]image.dcinside.com[#2]
