8muses Gallery Issue
blues82
Post by blues82 » 07 Nov 2017, 22:15
Downloading comics from 8muses.com with this template (http://www.webimagedownloader.com/templ ... -template/) was working flawlessly until just recently, when rather than saving each file sequentially (1.jpg, 2.jpg, and so on) in discrete folders for each starting URL, it suddenly started saving everything all together in the root folder of the download, with filenames like 6FH0ubbB1JyFHjZD3KACbnUsIw2d2ll8xcN-RrQBT827O1Tm8mYCWOy1Hu+LgkkCvIl5EqetxeMCVYxyiAHV2hQktkucxzCMywFyJ7jWaW3kOCL7kjAnaiYBRT3LM1ID6y1dElF62O2Yu3IiNnqcww==.jpg. Not very useful for putting comic pages in the correct order.
I'm not totally sure this is related, but it seems that most (or all) galleries now have the url for the first image on the page as /0 rather than /1, and I have a hunch this might be what's throwing off the template, but I don't have the knowhow myself to figure out where in the settings to tell it to compensate for this, or even for sure if that's the problem at all.
Any help would be greatly appreciated!
Re: 8muses Gallery Issue
Post by Maxim » 08 Nov 2017, 13:37
I updated the template. Please re-download and enjoy your comix:
www.8muses.com - album template
If there will be more problems - just let me know, I'll try to fix it ASAP.
blues82
Post by blues82 » 08 Nov 2017, 21:39
Works like a charm. Thanks so much!
Post by Maxim » 09 Nov 2017, 12:44
You're welcome! Be sure to let me know if it breaks again.
humanbein
Post by humanbein » 06 Jun 2020, 05:44
Maxim wrote:
09 Nov 2017, 12:44
you are the one who wants to know if something goes wrong and here you are :)
I'm using vers.9 and when i want to download galleries, many of them coming with different galleries and folders which are not related.
Post by Maxim » 06 Jun 2020, 10:59
Please try turning off [ Manual login ] and tell me if it works correctly.
humanbein
Post by humanbein » 06 Jun 2020, 15:40
Maxim wrote:
06 Jun 2020, 10:59
I did try and still having same problem. Every time when i started to download whole album i.e. ( https://comics.8muses.com/comics/album/ ... com-Comics ), 5 other albums are downloading with it and these 5 albums are always same ones.
If i want to download different album, that 5 fixed and same albums are again downlading with new project.
Post by Maxim » 08 Jun 2020, 11:59
This page contains 42 albums. And when Extreme Picture Finder finishes the download you have 47 albums? Right? What are the URLs of extra albums?
humanbein
Post by humanbein » 09 Jun 2020, 16:15
Maxim wrote:
08 Jun 2020, 11:59
Sorry for being late.
Here is 5 albums urls which are downloading an each time repeatly when i would like to download any whole album.
https://comics.8muses.com/comics/album/ ... x-Pictures
https://comics.8muses.com/comics/album/Various-Authors
https://comics.8muses.com/comics/album/Fakku-Comics
https://comics.8muses.com/comics/album/ ... ga-English
https://comics.8muses.com/comics/album/8muses-Comics
Post by Maxim » 10 Jun 2020, 16:35
I just checked everything, and just as I told you - you have to clear the [ Manual login ] box before you start the project. In this case extra albums are not downloaded. So, create your project, click [ Next > ] button to reach the last step of the [ Create New Project ] window, check the [ Show advanced project properties ] box and only then click [ Finish ] button.
In the project properties select [ Starting addresses ] section and clear the [ Manual login ] box. Then click [ OK ] and start the project.
