Download speed
noneed
Download speed
Post by noneed » 23 Sep 2017, 14:55
Is it possible to increase download speed anyhow?
thnx
Re: Download speed
Post by Maxim » 25 Sep 2017, 12:40
Extreme Picture Finder is downloading every URL at maximum speed that your connection can provide. So the first thing you can try is - increase the number of simultaneous downloads. The maximum number of simultaneous downloads is 30 which is usually more than enough.
If you want to download several projects at the same time - open Extreme Picture Finder settings (menu item [Tools -> Settings...]), select the [Advanced] tab and check the Allow multiple program instances box. After that you'll be able to start as many copies of Extreme Picture Finder on your PC as you need. Just make sure you download different projects in different program instances.
