this site is weird
KAIAD
this site is weird
Post by KAIAD » 03 Aug 2017, 20:26
simple
You can download images from the top address of this site
https://onehallyu.com/
But I can not get any images from the topic.
https://onehallyu.com/topic/166992-%E3% ... /page-1290
How should I solve this?
Re: this site is weird
Post by Maxim » 04 Aug 2017, 16:18
Yeah, this one may turn out a little bit tricky. First of all - what version of the program do you have? Earlier versions of the program could not handle long folder and file names and default folder name for project with this starting URL is super long. So you need to make sure you have the most recent version of the program:
http://www.webimagedownloader.com/download/
Second, tell me exactly what you need? All images from all pages of this (or any other) thread of this forum? Or images from this page only?
KAIAD
Post by KAIAD » 12 Aug 2017, 07:05
Oh I just saw it. Thanks for the answer
Now I am using version 3.38.0.0
And the problem was solved by shortening the folder name
But now I have another problem.
using this grateful program for a few days after this post
I found I could not get the twitter's videos and twitter's specific image extensions like "*.jpg:orig" "*.jpg:large"
sadly adding them to 'target file' dose not solve anything
I only got "*.jpg" from twitter link
Still referring to:
https://onehallyu.com/topic/166992-%E3% ... ry23033139
Post with "*.jpeg:orig"
https://onehallyu.com/topic/166992-【off ... p=23033139
And my goal is to get all the photos and videos on every page of this topic.
thanks for reading
Post by Maxim » 13 Aug 2017, 15:48
OK, turned out there is a bug when ":" is present in the file name. Gonna fix it and post here when it's done.
Post by Maxim » 14 Aug 2017, 13:45
OK, please download and install the fixed version:
It doesn't add a colon to the file name anymore, so original images from twitter that are embedded directly into the page will be downloaded now.
KAIAD
Post by KAIAD » 15 Aug 2017, 13:11
I experimented with a new version, and the jpg: orig file is well fixed!
however, there are still twitter issues
Reference:
Https://twitter.com/0423CHAEYOUNG
In this twitter account, a lot of photosets are made up of "* .jpg:large" files. EPF still can't get them
It would be cool if the app could completely download this kind of Twitter account
Thank you!
Post by Maxim » 15 Aug 2017, 13:33
Well, the main problem with twiiter is: it loads more content when user scrolls down. EPF can not scroll down.
Second: there are no direct links to jpg:large on the page you sent me. Take a look inside the page source and try to find "jpg:large" text.
But you can create such links with Custom Parsers like this:
Regular Expression: src="(https://pbs.twimg.com/media/[^"]+\.jpg)"
Result: [#1]:large
It will get you links to the large images for those images that are initially loaded when you open the page. Those that are loaded when user scrolls the page down are currently unreachable for EPF. But you can still get image from any post if you use a post link as a starting URL and the above Custom Parser.
KAIAD
Post by KAIAD » 15 Aug 2017, 13:57
Ok, I was surprised by quick answer
really helpful
I hope EPF can support scrolling down someday
Thank you for making a great program!
