If I download an image from the results, how to re-export updated CSV
dinnertan
Post by dinnertan » 20 Apr 2017, 06:45
After I run a search and download images, I end up with 500+ image.
Then, I delete the images I don't want.
Is it possible to regenerate the file CSV to exclude the deleted image?
Re: If I download an image from the results, how to re-export updated CSV
Post by Maxim » 20 Apr 2017, 13:43
Right now Extreme Picture Finder does not take into account if downloaded file exists when it exports CSV. Otherwise the export generation time would increase a lot.
Post by Maxim » 25 May 2017, 18:37
OK, in the new version it is possible. There is a new option on the Export file list window allowing you to include only existing files in the export list. You're welcome to download and install the new version here:
http://www.webimagedownloader.com/download/
