Request: Option to disable delete confirmation
coric
Post by coric » 11 Mar 2017, 03:18
Please consider adding an option to skip the confirmation that appears when a downloaded file is being deleted. Bonus points for a second option for only confirming if multiple files are being deleted. :)
Thanks for reading!
Re: Request: Option to disable delete confirmation
Post by Maxim » 11 Mar 2017, 12:02
OK, adding to the to-do list.
Post by Maxim » 22 Mar 2017, 12:34
All right, it is done in the new version:
Please let me know if there is anything else you think should be improved in the program.
coric
Post by coric » 22 Mar 2017, 16:10
Holy shit, thank you! Very much appreciated.
coric
Post by coric » 22 Mar 2017, 16:56
I'm almost afraid to ask, but would it be possible to make the next file be selected after a file is deleted?
Post by Maxim » 22 Mar 2017, 17:35
You mean in the main program window? But why?
coric
Post by coric » 22 Mar 2017, 19:37
Yes, in the file list of the main window. When I use the file list, I am always previewing files. The ones I don't want get deleted, but after they're deleted, I want to continue previewing files.
Post by Maxim » 23 Mar 2017, 16:14
OK, I that one is also done. And it's really more comfortable that way. Thank you for the suggestion! Re-download and re-install:
http://www.webimagedownloader.com/download/
coric
Post by coric » 23 Mar 2017, 18:05
Nice! Thank you once again.
