Download all pictures starting from same address at VK
OK. As it seems very difficult to download all pictures from af specific profile at VK.com, I did some tests at the specific profile, and found that all of the pictures are named https://vk.com/photoxxxxxxxx_yyyyyyyy
The X is constantly the same value, while the Y changes from each picture.
How do I tell EPF to download ALL the pictures that starts with the address https://vk.com/photoxxxxxxxx?
What is the right paramters to use?
Re: Download all pictures starting from same address at VK
Could you give me a couple of real URLs for tests?
Please try:
https://vk.com/albums-69933871
As you can see all the images within the album has the same "start-name": https://vk.com/photo-69933871_YYYYYYYYY
OK, I updated the template for this kind of albums. Please re-download:
Perfect. Will try later....
Hmm...I really don't get what to do?
Should I post some of the address-line, or??
Download and install the template from a template page here:
And create your projects... Make sure your User Agent in EPF settings is set correctly (shown on the template page).
By pastig the URL https://vk.com/albums-69933871 in EPF, som of the pictures are downloaded, but only the thumbnails.
How do I tell EPF to follow ALL the picture-adresses within the album to download the fullsized images?
Did you set the necessary User Agent in the Extreme Picture Finder settings? You can use your default browser's User Agent shown on this page:
http://www.webimagedownloader.com/my-user-agent/
