How to download from vk.com?
Aze
Post by Aze » 11 Feb 2017, 01:04
Hi Maxim
I need to download some pictures from a specific profile at vk.com, but the url of the album is not "https://vk.com/album-XXXXXXX_XXXXX" but instead "https://vk.com/albumXXXXXXX_XXXXX".
How do I download the pictures then? Hope you can help me out! Thanks for the support.
gemme
Re: How to download from vk.com?
Post by gemme » 11 Feb 2017, 10:26
Sorry for posting here as well but I don't want to open a new thread for my very basic problem: I can't even download from correct links. Here's a picture of the error I have. I get the same message when I'm trying to download the projects listed on the download page as well.
(The album on the screenshot is just a random example I found by googling, those I want to download contain more pictures, so I don't want to download them manually.)
Hope to get some help.
http://abload.de/image.php?img=aearzk0t.jpg
Post by Maxim » 12 Feb 2017, 17:30
Hi Aze and gemme.
Unfortunately vk.com album template does not work on every album. It actually does work on some albums (as you can see the template page - there are succesfully completed projects) but not on all :( The work on this template is still in progress and once I find a way to consistently download from vk.com I'll update this template:
and will report to this thread.
Aze
Post by Aze » 12 Feb 2017, 18:39
Thank you for the reply Maxim
I already installed the template for VK.com, but as stated the albums does not have "-" between album and the specific name.
Have you had any luck downloading from VK, from albums named https://vk.com/albumXXXXXXX_XXXXX?
Post by Maxim » 13 Feb 2017, 12:37
By the way, gemme, try setting this User Agent in EPF settings:
Mozilla/5.0 (Windows NT 10.0; WOW64; rv:51.0) Gecko/20100101 Firefox/51.0
and use current version of template. It may work for some of your albums.
gemme
Post by gemme » 13 Feb 2017, 16:05
That worked, thank you Maxim!
Post by Maxim » 13 Feb 2017, 20:26
I guess I'll add this information to the template page...
