EPF is great with other sites but, I am trying to download large images from http://www.photosight.ru/photos/category/15/
I'm not getting results, can EPF handle this site? Any help with settings would be great.
Can't download from photosight.ru
Re: Can't download from photosight.ru
Here is a ready-to-use EPF project which works with this website for you:
projects/www.photosight.ru-15.exe
Actually it works with all default settings, but it's rather difficult to make EPF download ONLY the selected category on this website. So I had to add every category page as a starting address and limit the exploration depth to 2. Check out the project settings for more details.
Thanks a bunch! Your project looks like it will work better than my attempt. I actually got it to work using the custom parser to download "large" in place of "thumb" since they were stored in the same folder. I set depth to "this page only" and added all the start pages like you did. I'll use your setting and modify to download some other categories.
You're welcome! Feel free to write anytime you have a question.
