Support for double-byte character systems
groink
Post by groink » 01 Apr 2014, 03:20
I'm trying to find a way to create a web picture search, searching for a phrase that is written in a double-byte character system. When trying to do so, EPF translates it into a string of %3F, which is basically "?" in hexadecimal. I tried translating to UTF-8 hex myself and pasted the string into EPF. For example, "スーツ" in Japanese translates to "%E3%82%B9%E3%83%BC%E3%83%84" in UTF-8. I pasted the UTF-8 string into the program. But, the search engines attempt to search literally for the UTF-8 string, and not the actual double-byte characters.
I can manually in the web browser enter the following into the URL:
http://www.google.com/search?q=%E3%82%B ... C%E3%83%84
And Google will automatically translate the string to "スーツ".
So, I'm figuring that EPF must be somehow sticking the search string into quotations, or something along those lines.
I only have four days left on the install, so if there isn't a quick solution to this, I'll have to search for a tool elsewhere. Thanks!
Re: Support for double-byte character systems
Post by Maksym » 02 Apr 2014, 19:11
OK, the new version is released with the support for multi-byte characters in the search phrase:
groink
Post by groink » 04 Apr 2014, 12:21
Tried it, and it does work!!!! Thanks for letting me try the beta version.
Post by Maksym » 04 Apr 2014, 12:26
Be sure to download and install the release version from the link in my previous message.
utomo
Post by utomo » 05 Apr 2014, 11:02
I read that this is final version instead of Beta version
http://exisoftware.com/picture_finder/whats_new.html
Version 3.24.3.0
Multi-byte character support in the built-in picture search
Flickr.com search fixed
Post by Maksym » 05 Apr 2014, 13:13
Yes, it's a release already.
ebikeric
Post by ebikeric » 26 Apr 2023, 20:34
I'm having this same problem with 3.64.1 version.
Post by Maksym » 27 Apr 2023, 11:01
What kind of problem do you have? I just created and ran a search project with the phrase "スーツ", and here is the result:
ebikeric
Post by ebikeric » 27 Apr 2023, 17:05
The starting address tab doesn't recognize these double byte characters.
For example "https://foamgirl.net/tag/%e7%88%86%e6%9 ... ekokoyoshi"
Post by Maksym » 27 Apr 2023, 18:49
I just tried - Extreme Picture Finder downloads easily from this website. What is your actual problem? Does Extreme Picture Finder download any files from foamgirl.net for you with the built-in generic template called [Download all images from entire website]?
