TGP sites
ds500
TGP sites
Post by ds500 » 02 Mar 2014, 20:21
I cannot download any images from TGP sites such as Pichunter and Image gals.
I am only specifying the starting address such as http://pichunter.com
Do i need to specify more URLS or special filters?
Thanks for any help.
Re: TGP sites
Post by Maksym » 03 Mar 2014, 12:06
I just tried this webite - works just fine. So, if you want the latest galleries from pichunter.com, then specify the home page as a starting address. If you want galleries from a certain category, then you specify every page of this category as a starting address (use the built-in URL generator for this). For example, for category "Teens" the starting address list is:
http://pichunter.com/tags/all/Teen/
http://pichunter.com/tags/all/Teen/1
http://pichunter.com/tags/all/Teen/2
http://pichunter.com/tags/all/Teen/3
http://pichunter.com/tags/all/Teen/4
http://pichunter.com/tags/all/Teen/5
http://pichunter.com/tags/all/Teen/6
http://pichunter.com/tags/all/Teen/7
http://pichunter.com/tags/all/Teen/8
http://pichunter.com/tags/all/Teen/9
http://pichunter.com/tags/all/Teen/10
http://pichunter.com/tags/all/Teen/11
http://pichunter.com/tags/all/Teen/12
http://pichunter.com/tags/all/Teen/13
http://pichunter.com/tags/all/Teen/14
http://pichunter.com/tags/all/Teen/15
http://pichunter.com/tags/all/Teen/16
Of course, the exploration type should be set to "TGP". Also I suggest you to remove the default Custom Parsers and add the following Excluded URLs:
/tags/
cams\.
/models/
blog
forum
reviews
I added this project to the built-in online project database under the "Erotic -> Teens" category. So you can download it and use as a template for any other category of this website.
