Great program. Happy to have found it.
Perhaps you can help before I start scratching my head.
i would like to crete diffrent albums and access them using Nav buttons
from the "home" pages.
Any help and suggestions much appreciated. Thank you.
Nav menu under page title.
Re: Nav menu under page title.
I'm not sure I understood you correctly. Are you asking how to add "nav buttons" with links to the galleries you create with Extreme Thumbnail Generator to some of your "home pages"? If yes, then here is the sample code:
<a href="/gallery1/index.html"><img src="/images/your-nav-button.gif"></a>
This one is for the gallery you uploaded into the "gallery1" folder on your server.
Here is some more information on how to embed galleries created with Extreme Thumbnail Generator into any website:
http://www.exisoftware.com/thumbnail_ge ... llery.html
(scroll down to Step 5).
Yes, thank you, that is what I wanted to do.
I did sort it out along the lines you mentioned.
It works quite well. Very nice program.
Shouldn't stay up so late! :-)
