Non-stop projects
jmalinie
Non-stop projects
Post by jmalinie » 28 Mar 2017, 21:56
i want if a program complated the project , it will start a new project ,
i have multiple projects and need to check all time if a download complated or not .
is it possible ?
thanks
Re: Non-stop projects
Post by Maxim » 29 Mar 2017, 12:44
You can set a project to start after current one is finished in the project properties, "After completion" section. Take a look at this screenshot.
And you can create a chain of projects starting one after another like this. Later we'll add a possibility to download all projects in a category automatically.
