Help in downloading images only from list of urls
greenflag
Post by greenflag » 01 Sep 2009, 00:52
I would appreciate your help with a simple task that I can't get to function properly. I am trying to load multiple urls, example;
http://www.postbrook.com/traditional-rugs.html?p=2
http://www.postbrook.com/traditional-rugs.html?p=3
..and only wish to download jpgs on each of these pages. I can do that successfully, but the application then starts to download from pages linked to these pages. My settings are;
Starting address:
Regular site.
Current page only
Naming: Keep original name
Thank you.
Re: Help in downloading images only from list of urls
Post by Maksym » 01 Sep 2009, 11:03
You can add the following "Excluded URLs filter":
It means "exclude all addresses". And then add the following "Included URLs filter":
\.jpg$
It allows all addresses that end with ".jpg". I just tried it - worked perfectly. And I think we'll have to fix the "Current page only" functionality.
greenflag
Post by greenflag » 02 Sep 2009, 18:34
Maxim,
Thank you for the instructions. Works great. Will be purchasing this shortly.
