I am evaluating the program and I am having trouble trying to download the images from the following page
http://www.kohls.com/kohlsStore/mens/on ... usives.jsp
The search returns no image files
So far I am please with this program and the support through this forum.
No images on search
Re: No images on search
OK. You have to download and install the most recent version of Extreme Picture Finder - version 3.13.5. It was just released and it's now possible to save files without extension (this is just your case).
So, your project settings are:
Starting address: http://www.kohls.com/kohlsStore/mens/on ... usives.jsp
Exploration type: Regular, Current directory and deeper, Download files from external websites - checked
Target files: *.
Save - Naming: Change extension to "jpg"
Excluded URLs: ENDECA_SEARCH_INPUT
You can also set minimum file size to 5 or 10 to prevent thumbnail download.
Target files: *.
Perfect!! Thanks for your quick reply and solution. I downloaded the latest version and it works like a charm. I've evaluated the program enough that I've decided to purchase. I've used another program in the past but I will be using Extreme Picture Finder from now on.
Thanks again
Thanks again
