wallpapers
nverge
wallpapers
Post by nverge » 22 Dec 2010, 11:02
sir,
I have two problems. I want to download wallpapers from sites like santabanta.com, indiafm.com,glamsham.com
which has different structure. I would like to know what query should be given so that i could download new wallpapers or directory of specific
actresses?
Thank You.
Nirad
Re: wallpapers
Post by Maxim » 22 Dec 2010, 22:25
Nerad, please tell me exactly what wallpapers (from what directory or address or specific size) from what website do you want to download and I'll try to help.
nverge
Re: wallpapers
Post by nverge » 23 Dec 2010, 07:23
hi Maxim,
look at this link
http://www.santabanta.com/wallpapers/ca ... rad%20pitt
now i don't know how to use strings. there are categories like male celebs, female celebs,indian celebs and then sub-categories
like brad pitt,hugh grant. I would like to have all wallpapers of say 1024x768 res. what settings should i use?
Thanks for your help.
Nirad
nverge
Re: wallpapers
Post by nverge » 03 Feb 2011, 12:55
Hi Maxim,
Thanks for your valuable help.
I will definitely try this.
Some other problem
I have found this great site www.skins.be
now again if i want to download 1024x768 of celebrities.
there is different directory for this resolution ..... i guess
http://wallpaper.skins.be/keira-knightl ... /1024x768/
Please tell me now what should be the setting?
your help is valuable because what you told me earlier is still hard to memorize
and comprehend as one should know HTML tags in this case.
Thanks & Regards
Nirad
de2apandi
Re: wallpapers
Post by de2apandi » 15 Feb 2015, 15:13
Hai maxim please update setting for this site http://www.santabanta.com
for this
http://www.santabanta.com/wallpapers/in ... ties(f)/2/
size wallpaper 1920x1200
thanks
jazzle
Re: wallpapers
Post by jazzle » 25 Mar 2015, 20:54
I am after wallpapers as well. http://wallpaperswide.com/ These are free so I'm not trying to cheat the system, just save from the amount of clicking. One caveat, you have to click on the image, then click download, so perhaps that's why it doesn't work? I followed the suggestions above, but cannot get it to work. I registered on the site and used my account login in EFP, but nothing still. Any help would be awesome. I'm trialing EPF right now to see if I'm interested in buying. Hoping this works.
Re: wallpapers
Post by Maxim » 26 Mar 2015, 16:28
Here is the template for this website:
Also please check out other templates for wallpaper websites here:
http://www.webimagedownloader.com/templ ... allpapers/
nverge
Re: wallpapers
Post by nverge » 09 Feb 2017, 13:16
Thanks for your help and I am able to download wallpapers.
Now could you tell me what to do if I want to download high resolution pics say 1980x1080 from following page
http://www.santabanta.com/wallpapers/in ... /2/?page=1
Thanks & Regards,
Nirad
Re: wallpapers
Post by Maxim » 09 Feb 2017, 13:23
Simply use this template:
Or this project I created with the above template:
http://www.webimagedownloader.com/templ ... ect/87301/
