imgsrc.ru download original-sized images
mattsmizzy
Post by mattsmizzy » 28 Jul 2017, 04:53
Everything is working great for the album and full user templates for imgsrc.ru. But it does not appear to be downloading the full size images on a page any more, if there is a link for one. I swear at one time it did. Not sure when it stopped working.
Heres a link to a folder with some Full size images within the same page.
http://imgsrc.ru/schiller_ms/a1665926.html
Thanks!
Re: imgsrc.ru download original-sized images
Post by Maksym » 28 Jul 2017, 16:00
This website changed the way it delivers full-size images recently, so we updated all the templates to reflect those changes. Now you simply need to re-download the templates:
http://www.webimagedownloader.com/templ ... imgsrc.ru/
And start creating your projects with new versions of the templates. Also make sure you have the most recent version of the program:
http://www.webimagedownloader.com/download/
I used the "imgsrc.ru - album template" template with the address you provided and Extreme Picture Finder saved 33 full-size images.
mattsmizzy
Post by mattsmizzy » 30 Jul 2017, 00:27
I may have cheers'd to early. Tried the templates. Still wasnt downloading. Updated to latest version of software, deleted templates and re-added them. Still not downloading full size pics from that link.
I notice the program is still hitting all the
b7.us.icdn.ru .... jpg image links. which are the normal viewing page sized images.
But i never see the program hit the full size image links yet, IE:
http://o7.us.icdn.ru/s/schiller_ms/7/im ... 797AzK.jpg
I have not changed any settings at all, just default. That above image comes out as 162 Kb every time instead of the 1MB plus image size it should be for full size... Maybe i do need to tweak a setting?
Also on a side note, before i even tried the new templates the first time, i copied the settings from the previous version of the template properties of the starting url's and additional starting urls in an effort to see the difference between new and old so i could try to deduce the issue and try to fix it if it happened again, (of course would let you know here as well so it can be updated for everyone else). But when i looked at the new templates properties, they actually matched the old template properties for starting url's and additional starting urls. So not sure where the change took place? just found that odd.
I think i see it, custom parsers and included urls deeper in properties. but not sure how that works. Probably should be working i suppose but just isnt.
Thanks for what ever you can do or suggest.
Cheers!!!!! Tried to figure it out my self but i dont really know programming, even the basics of regular expression. Thanks :-)
Post by Maksym » 30 Jul 2017, 12:22
Oh, you mean original-sized images, not full-sized... Yeah, they are currently not included in the templates... Once they were there and in this case EPF downloaded both full-sized and original-sized images. Didn't look good... So original-sized were removed because not every album has them, while full-size images are always there... It's not difficult to add them back, but how to make EPF download only original-sized without full-size images when they are there - that's the problem.
Post by Maksym » 31 Jul 2017, 14:51
OK, looks like I finally managed to update the templates so that they will download only original-sized images from any imgsrc.ru album if they present, if not - full-size (or big) images will be saved. Enjoy!
And let me know if there are any other problems with the templates ASAP. I'll fix them.
mattsmizzy
Post by mattsmizzy » 02 Aug 2017, 03:48
I would have been satisfied even if it download both images of different sizes. Just as long as it got the original largest size image, which is usually an additional link on the page that said Full size image. But if you got it to download the larger full size image link and avoid the smaller image of the same image, then bravo!! Will give it a go in a little bit and see how it goes. Thanks !
mattsmizzy
Post by mattsmizzy » 04 Oct 2017, 07:10
just updated my templates. looks like just the imgsrc.ru new templates, think albums ver 26 and all user albums ver 24 are not working at the moment. just keeps hitting *.html#bp and *.html with out grabbin pics. Thanks for your speedy updating.
Post by Maksym » 04 Oct 2017, 12:44
I updated all templates:
They all work only with Extreme Picture Finder 3.39.1 and above. If you have EPF 3.39.0 or 3.38 or lower - templates won't work.
