Moving EPF Settings to a new PC
Razorking
Postby Razorking » 19 Nov 2016, 22:55
I am upgrading to a new PC and am in the process of retiring the old one. I was able to install and license my copy of EPF on the new PC, and I have my files from the old PC moved to the new PC. Is there a way to copy settings from the old PC to the new PC so the EPF will know the history and what files it has already downloaded form sites - when it ran on the old PC?
Hope that makes. Trying to move installation from old to new PC in a seamless manner.
Re: Moving EPF Settings to a new PC
Postby Maxim » 20 Nov 2016, 14:44
If you already have your projects on a new PC then you need nothing else.
Basically, all you need when you move EPF from one PC to another is EPF "Data folder". I mean entire content of this folder - all files and folder inside. You can find the location of "Data folder" in EPF settings, in the "Advanced" section:
Return to “Extreme Picture Finder”
