EPF freezes since installing 3.30.1.0 update - solved
coric
Post by coric » 15 Oct 2016, 04:12
I'm running Windows 10 Pro x64 (1607). I just installed EPF 3.30.1.0. It freezes as soon as I select a project and click the Update toolbar button. I have no more info beyond that.
I reinstalled 3.30.1.0 and it didn't help anything. EPF was fine before installing 3.30.1.0.
coric
Re: EPF freezes since installing 3.30.1.0 update
Post by coric » 15 Oct 2016, 04:22
Restored EPF 3.30.0.0 and it works fine.
Post by Maxim » 15 Oct 2016, 12:50
Does anyone else experience this one? I tried updating all my projects - worked perfectly. Can you send me your project file to support@exisoftware.com for tests? Also, what about starting a new project in 3.30.1.0? Does it work for you?
coric
Post by coric » 16 Oct 2016, 19:37
Still freezes even after I create a new project (brand new--I don't mean cloning an existing project).
Just emailed an EPR file to you.
Thanks.
coric
Post by coric » 17 Oct 2016, 18:48
I found the problem. It was Microsoft EMET. Specifically, the SimExecFlow mitigation.
I have EMET 5.5 configured for EPF.exe, since EPF accesses untrusted data. For some reason, 3.30.0.0 worked fine with this EMET configuration, but 3.30.1.0 does not. But once the SimExecFlow mitigation is disabled for EPF.exe, the issue goes away.
