Additional search engines
optimusx3
Post by optimusx3 » 14 Oct 2016, 03:38
Hi
Would like to know if we could add additional search engines to the "web picture search" list of search engines?
Re: Additional search engines
Post by Maxim » 14 Oct 2016, 13:22
You can tell me which ones do you need (along with URLs) and we'll try to add them.
optimusx3
Post by optimusx3 » 14 Oct 2016, 18:13
DuckDuckGo please
https://duckduckgo.com/
Post by Maxim » 02 Nov 2016, 17:24
Done. DuckDuckGo is now in the list of search engines:
optimusx3
Post by optimusx3 » 04 Nov 2016, 20:05
Hi
Thank you for that.
Is ther anyway that the -
Safe search blocked some results
can be disabled/turned off via your program.
You normally have to turn it off permently when you do you first adult seach.
Regards
Post by Maxim » 05 Nov 2016, 16:55
You can turn off safe search when you create a new search:
But you can get "unsafe" results only from Google in EPF.
optimusx3
Post by optimusx3 » 05 Nov 2016, 19:57
Hi
Yes, I know, but duckduckgo has it's own safety setting that is auto turned on and thus gives no results.
Also, how can I upload an image on this?
Post by Maxim » 05 Nov 2016, 20:09
You can use third-party image hosting.
